Does a starter motor need to be vehicle specific, as in, I have a 1.0 L, would a motor off another engine size for example be ok?
Thankyou!
Starter motor
- bstardchild
- Moderator
Re: Starter motor
I fitted a 1.0 starter to a 1.4 - no issues apart from I had to change the wiring pluggina wrote:Does a starter motor need to be vehicle specific, as in, I have a 1.0 L, would a motor off another engine size for example be ok?
Thankyou!
I had it reconned first and was carefull to replace the brass bush in the gearbox bell housing it should come with a new/refurbed starter
The failure of the bush is frequently the cause of poor starting and batteries being killed.
