Induction Kit
Mk4_Scotland
Induction Kit
Post by Mk4_Scotland »
Any1 know who sells the inductions pipes that come from the throttle body down to the big gap at the left hand side of the engine? Don't want a little cone sittin on top of my engine looks crap and doesn't get enough cold air! P.s 1.4 8v
KarlM
Post by KarlM »
I looked into it a while back and couldn't find anything, but you could look at customising a Bonrath PowerRohr from a Golf to the original filter housing
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
I made my own using silicon hosing and metal tubing.
8)
hardhitter
Moderator
Post by hardhitter »
Thats probably the best idea from Josh.
All you need to do is measure the diameters, lengths and angles needed, then work out where the filter will go and stick a suitable size cone on the end.
simon pope
Post by simon pope »
when u buy an induction kit u generally get some sort of hosin with it, wot i did was use the hose for ya RAM air induction, next to the radiator there is a plastic cover, cut a hole in that the same size as the hose and feed it through upto ya front grill u should get maximun suction then!!!!
Mk4_Scotland
cheers guys, nice quick reply fo my first post!
KarlM
Post by KarlM »
8-)
