newbie to uk polo
timmywills17
newbie to uk polo
Post by timmywills17 »
:lol: Hi i new to the forum i bought a polo 1997 1.4 3dr last week and i have a prob with the central locking when i open the door from the drivers side the passenger does not open unless i open it with the key i wanna know if i can fix this prob without 2 much hassle. any ideas thanx
rydale13
Post by rydale13 »
hi mate,
welcome to the forum. It sounds like one of the vacuum/air lines is damaged.
the central locking pump is in the boot on the right hand side (where the 1st aid kit should be)
take it out and check to make sure all pipes are correctly inserted...
The central locking pump is a black box with a cylinder shape on top of it.
1der
Post by 1der »
Get some pics up of your car for us to see :wink:
timmywills17
thanx
:lol: cheers mate will check it out tomoro morning
yosin
Post by yosin »
i had the samee problem..one of the pipes wasnt correctly inserted...sorted it out but now its happening again but the whole central locking system aint working..
any ideas? :roll:
timmywills17
help
yosin wrote:i had the samee problem..one of the pipes wasnt correctly inserted...sorted it out but now its happening again but the whole central locking system aint working..
any ideas? :roll:
wot do u mean the whole central locking does not work? can u still open the car?
yosin
Post by yosin »
i mean like it doesnt lock all the doors and boot...
i have to use the keys now -.- :?
timmywills17
any1
does anyone know if this prob can b solved by buying a remote cl kit? :roll:
yosin
Post by yosin »
timmy: try going to the garage they would sort it out cos i had the same problem, it would be cheaper than buying a whole cl kit :?
cost me like 20 bucks to sort that out
timmywills17
kool
yosin wrote:timmy: try going to the garage they would sort it out cos i had the same problem, it would be cheaper than buying a whole cl kit :?
might jus do that its just that i was plannin on getting the remote cl kit that gives u headlight flash and dat beep sound do i still need da vacuum pvmp fixed?
randomage
Post by randomage »
the vacuum pump is what works the central locking so yeah you will need it. i had this problem when i first got my car, turned out someone had unplugged the pump from the electrics! when we plugged it back in, we found out why.... theres a leak in mine somewhere so when i lock it, it keeps whirring for about 30 secs. the look on peoples faces when i walk away from my car, whirring like mad is totally priceless!
Rupie
Post by Rupie »
hey welcome to the forum!
hope you get your locks sorted out!
timmywills17
thanks
dempsey 5
Post by dempsey 5 »
mine does the same :evil:
lee s3 plo
Post by lee s3 plo »
welcome !!
