Well, The water pump it done, It doesnt over heat, Its all good, Well almost. I was supposed to be doing the work on the engine, I got home and my other half's dad had done it. When he fired it up, I wasnt convinced it was right, I wouldnt idle and sounded rough. After he had gone, I looked at it my self, Couldnt see anything obvious. I checked the marks he had put on the timing belt, They didnt line up. So I think it a tooth or two out. Problem is I dont know whay should line up to what, I dont trust the marks the he put on, I want to start from scratch. Has anyone got and pics of the timing marks on the crank or flywheel and the cam sprockets??
TIA
Paul
URGENT! 1.4 16V AFH engine, Timing marks
Avinitlarge
Avinitlarge
