MK4 Bushes Need Replacing Garage Recommendation Needed
Bedi
Post by Bedi »
Went to get tracking/Cambers done on my lowered MK4 but couldn't because my bushes need replacing....
Does anyone have a garage they could recommend to me in the (London area) to get the job done...
Also are standard bushes from VW good enough for a lowered car or do many on you get aftermarket bushes?
Would you recommend I buy my own parts and how much am I looking at to get the job done?
Mike
Post by Mike »
http://cgi.ebay.co.uk/POWERFLEX-SUSPENS ... .m14.l1318
Should take a mechanic about a hour to fit
Tim_GTi
Post Whore
Post by Tim_GTi »
Yep powerflex are said to be very good.
Bedi
Post by Bedi »
I have been told that I may aswell replace the ball joints on my car while I'm getting my wishbone bushes done...
What do you guys think (car has done nearly 80K)?
Are genuine VAG ball joints good enough or do I need to go aftermarket again?
Thanks for the help guys.
Mike
Post by Mike »
it really depends on how far you want to go, but it would give you added feel to the car that 80k has worn away.
I just replaced the bushes, it's given the car a better more postive feel.
if i was in your shoes, i would just change the bushes and get the camber and tracking done and take it from there, and poss look to having the ARB bushes( powerflex don't list any for Mk4's just universals, maybe some other company lists them but i've not really looked) and ball joints at a later date.
Bedi
Post by Bedi »
Mike are VAG Ball joints good enough for a lowered MK4 or is aftermarket recommended?
You believe that I should just get my Wishbones replaced and look at the ball joints at another time... But the guy who recommended me to do both said so because he said that the time/labour will be about the same....
what do you think?
Mike
Post by Mike »
I would go for OEM parts every time, unless they are a uprated item, but somethimes the expense out weights fitting them, best to have a ring round and check part prices, but motor factor parts should be fine unless your planning on doing the Paris-Dakar Rally this year.
If the guy said the price is about the same go for it i say, then it's one thing less to go wrong on the next MOT, had my tracking checked today after fitting my bushes, it was well out -.9 and now the car don't handle like a milk float
Bedi
Post by Bedi »
Thanks for the help Mike :D
