My central locking is playing up, sometimes doesn't work properly, sometimes does.
Does anyone have any advice on how I can fix it?
Factory Central Locking Playing Up?
david burton
crodgers
Have you fitted mark5 rears? I fitted them not so long ago and as it was gettin dark pretty quick, i failed to realise that the mark5 rears didnt have a seal on them like the original mark4s. My central locking was playing up and only worked when it wanted. Then it stopped working all together with the fuel light coming on and not being able to get the cap open. I pulled the pump ut and took of the lid and you could clearly see where water had got in and blew a circuit on the board. carried out a temporary fix and it worked fine but didnt want to risk it so stuck a new pump in.
But if your central locking does pack in all together that the hose off the pump and suck/blow into it and this will open the locks to avoid what happenned to me at the petrol station.
