Morning all.
My Volkswagen polo 2001is in need of a gd service 77,000miles. Could any one advise me what needs replacing, etc., and is it something I can easily do. I have been quoted £70 for a private garage to complete the job excluding parts.
The cambelt was changed 3,000miles ago
Thanks in advance
Phil
Car servicing
Re: Car servicing
Errrrm good service.......
Spark Plugs (go for Split Fire Triple Platinum last upto 100,000 miles)
Oil Change (go to a VW Dealers or halfords)
Oil Filter (go to VW or GSF or halfords)
Fuel Filter (go to VW or GSF)
Air Filter (go to VW or GSF or get a perforamance one)
Brake Fluid change IF the vehicles brake fluid has not been changed 2 years!
Check brake discs and pads to see if there is a resonable amount left.
Clean throttle body with some carb cleaner from halfords
that should have your car running perfect!
coogee
Re: Car servicing
Good service= full serviceNFS wrote:Errrrm good service.......
Thanks for the help, greatly appreciated
Phil
coogee
- Tim_GTi
- Post Whore
howdu get it all for that cheap? The leads normally cost £40 alone.jordan eff wrote:the air filter is very easy, did this myself today on mk mk4 and took less than 5mins to take out the old one and fit the new one
recieved all my bits today for my service
spark plugs
air filter
fuel filter
oil filter
distributer car
HT leads
all the bits cam to £49
and its booked in to have the timing belt changed
coogee
- Tim_GTi
- Post Whore
Re:
Ahh is it, must be the GTi ones then.polo-sib wrote:Sounds about right leads are more like £20 from the last two sets I have bought.Tim_GTi wrote:howdu get it all for that cheap? The leads normally cost £40 alone.
Don't forget the rotor arm! when doing the distributor.
