i have just bought some clear indicator covers for my 1996 polo 6n, and want to fit them, but dont know how to go about it.
help please?
thanks
fitting indicators
- lolhoward
Re: fitting indicators
Side indicators - just pop out. Prize one side out and they should just pop out. Then just push in the new ones.
Front - if the same as Mk5 you pull the pin up (under the bonnet in between the headlighst and indicators) and then just pull them forwards (beware of breaking the plastic clips). I did this on my old Mk4 but cant remember if its the same, sure it is.
If you are talking about side repeaters;
Push them towards the rear of the car, they should just push out. Look in the manual, it gives a nice diagram.
Then, un-clip the old bulbs, and fit the new one in.
If you are talking about front side indicators;
http://www.uk-polos.net/view ... =10&t=2148
Hope that helps!
Hope that helps!
george-225
thanks guys ill give that a crack this weekend.=)
- lolhoward
Screwed down, not plastic screw/clip. Knew it was simular. You cant go wrong mate, peice of cake.
