Now I imagine the fronts would be fine, but the rears are a bit of a concern...although I do like poke, but finding it hard to picture just how much poke that would be on a 9n
I used to have a set of 19 by 8.5 on my polo a while back, and the poke is cool looking but the problem your going to have is the rubbing on the bottom part of the arches
i ended up taking paint off my arches when i had a full car a couple of times, so you cant have your car that low unless you want to pay a hundred quid sorting the paint on the arches, you might as well have to cut out a some parts of the mud flaps so that the wheels dont rub them away
there is also a flat piece of metal that you will have to bend back at the back of the rear arches you will know what i mean when you see the rub marks
