loss of power
antony1
loss of power
Post by antony1 »
hi there guys i have a 2001 y reg 1.9 turbo diesel polo estate and it runs fine till about 2200-2400 revs and the power really fades off and it power seems to really lack up until then its grest does this in every gear but then somtimes it will not do it on the odd occasion any ideas
cheers ant
nazzurro19
Re: loss of power
Post by nazzurro19 »
well the other day i had this problem it wudnt rev past 3k and as soon as i got to 3k it wudnt rev anymore nor build up speed VW seem to do a thing called "limp" mode god knows why cause i had no warnin lights or anything all i did was switch the ignition off and back on and problem solved, get Vagcom and run it thruogh and see what fault codes it brings up
vw55raz
Re: loss of power
Post by vw55raz »
check your fuel filter and clutch, or it could be that your timing belt was fit incorrectly if changed recently.
Tim_GTi
Post Whore
Re: loss of power
Post by Tim_GTi »
you also want to keep HT leads and your coilpack. I'd give the throttle body a good clean in the meantime too to see how that holds up.
