HELP!
JayDee
HELP!
Post by JayDee »
I have a 6n2 1.4 16v. Had it since a was 16 and never had any problems. Recently its started to play up. When pulling away it will hesitate jerk violently then drive smoothly. I am a mechanic so ive checked near about everythin. Im thinkin along the lines of a new throttle body...any ideas?
Re: HELP!
Tried replacing the temp sender?
JayDee
Re: HELP!
Post by JayDee »
Thats no really telling me a lot mate. Im jap cars through and through....
Re: HELP!
Being a mechanic I thought youd have know that :P
The polos have a Temperature sender located in the thermostat housing that often fails at some point and causes idling problems, fuelling problems, and general instability. It would be worth changing it as its an inexpensive part to replace.
revolutionrock
Re: HELP!
Post by revolutionrock »
Check the ignition cables!
:D
/Johan (sweden)
JayDee
Re: HELP!
Post by JayDee »
Well..thats a bit better...the other answer was about as much use as a choclate tea pot :D
Sender? Do you not mean sensor?
Re: HELP!
Sender or sensor it can be called either. It sends the temperature to the ECU :P
JayDee
Re: HELP!
Post by JayDee »
Thanks mate, never heard it being called a sender.
Suppose were all different
revolutionrock
Re: HELP!
How is it going? :)
JayDee
Re: HELP!
Post by JayDee »
Ill get round to doing something eventually.
It only really happens when you kick its hole in but when you drive "sensibly" it seems to be okay lol
