Just spent the weekend fitting some coilovers to my Gti
, all went on okay Except the left front wheel has horrendous positive camber i.e the top of the wheel is much further inwards than the bottom.
Right wheel: all okay
Left wheel: a different story, see how it bends in at the top comapred to the right one
This causes the tire to rub against the spring. ive tried adjusting the ride height, i knew the camber would be out after fitting the coilies but surely not this far out?! and it's only on one wheel! The car is undrivable as a result.
If you guys can think of anything i could try or what i may have cocked up when putting them on then i'd be very grateful.
