Vibrating mirror
Vibrating mirror
I have a reeally annoying vibrating mirror when i listen to songs with alot of bass.
Its annoying because my passenger side mirror doesnt move at all wher as the drivers side does.
Im wondering if its because the 'shell' of the mirror is cracked at the bottom?
Or if its something holding the mirror its self in place is coming loose.
im not really sure how to check.
Thanks.
Thanks.
- Gary Gee
Re: Vibrating mirror
dynamat your doors?
That could be an option, but what would be the need for it if one side doesnt vibrate, when they are the same door?
- Gary Gee
its either that or get ur mirror sorted... its probs cos of the crack as mine vibrates when cracked but if my music is loud enough to vibrate it i cant hear it
Ok cheers. ill have a look at getting a stubby to replace it.
superglue where it rattles!
worked fine for me:)
It's the mirror it's self that vibrates. Can't super glue that then the electric switch won't
move the mirror lol
move the mirror lol
The mirror shouldnt vibrate unless the mounts are loose on the back of the glass, or the adjuster motor screws arent tight.
What's the easiest way to access it to make sure every thing is done up tight?
Take the mirror case off, and remove the mirror glass. Check to make sure no clips are broken, and tighten up any loose screws on the mirror motor etc
Does the case just pop off?
pull gently upwards
theres also a screw on the underneath holding the casing on i believe?
mine was only case rattle not the actual mirror
The mirror cases arent screwed on. Only clipped. The screw holds on the black undertrim
you sure it just pops off?
Ive tryed my hardest to pull the damn thing off and i cant get no where.
I dont want to force it off because i dont want to snap it. I tryed to pry it off but that just damaged it.
And the screw underneath is stuck in there like a good'n. So that wont budge,
There is another hole underneath covered by a rubber cap.. has that got to do with any thing?
