would 7.5" alloys fit ok on the GTI or would they require work?
wheel width question
Re: wheel width question
they should but you may need a bit of stretch on the tyres
- Tim_GTi
- Post Whore
100% depends on the ET of the wheels mate.
wheelmanwayne
perfect mate i run 7.5x16 et20 with 195/40 /16 toyo's and it only scrubbs with a full load over a dip in the road
haha i ran 8.5" on the back of my old GTI...
Tomo, what was the offset for the rear?? Did you do any modifications to the arch, im just about to buy the same wheels but they are in 9j
thanks
thanks
im afraid i dont know the final offset that the wheels had. I had the arches rolled and pulled and run a 195,45 tyre on them. It wasnt very low and still rubbed a bit sometimes. I personally think 9" would be far too wide, 8.5" was pushing it.turkpolo wrote:Tomo, what was the offset for the rear?? Did you do any modifications to the arch, im just about to buy the same wheels but they are in 9j
thanks
cheers, have bought them soo ill have to fit them on wateva it takes. Planing a good stretch with camber to see the results, if i require any arch work. I will upload pics when its all done..
