accelerator needs more pressure
kipper
Post by kipper »
probably not the best way to describe it but have noticed probably started about 5 months or more ago when u push the accelerator down i need to push it down more and gett he revs up higher to make sure the car moves and doesnt stall. car still works etc just wondering if n e one might know a possibly cause or the reason?
thanks
nigelelliott394
Re: accelerator needs more pressure
Post by nigelelliott394 »
I had an old peugeot 206 where the throttle cable snapped... the car just didn't accelerate at all and the pedal lost all 'pressure'. Had to have a new throttle cable fitted before it worked again. I'm not sure how 6n2's are... but that MAY be the problem. I'm sure someone will be along soon to confirm :)
kipper
Post by kipper »
i can still move and pick up speed it just isnt as sensitive as it use to be.
my mum has a 6n and the accelerator is very nice and responsive.
just adjust the throttle cable to take up any slack.
kipper
Post by kipper »
i suppose that could make sense really. where do u adjust it tho?
Where the cable goes into the mount on the throttle body, there is a ribbed plastic tube with a clip, you just take up the slack in the cable, and move the clip to the appropriate position.
kipper
Post by kipper »
excellent. i'll have a look into that tomorrow.
thanks
kipper
Post by kipper »
i dont believe there is a cable. i had a look in the engine and couldnt see one and when i read the haynes manual i read that there isnt a cable as its done electriconically.
is there a way to adjust it manually or would it be a garage jobby?
Brad.
Post by Brad. »
Yeah, only the GTI's have the throttle Cable. All the other models are Electronic i think...
No lol - the GTIs are electronic - all other models par the 1.4 16V 100bhp model have throttle cables
Check the back of the pedal to see if there is a cable attached to it.
What engine is yours kip?
kipper
Post by kipper »
not sure but on the log book it says engine no: AUC(then about 6 numbers)
is that it or would it be somewhere else?
1.0 8V then
Should be a cable throttle. I think the cable is located underneath the back of the throttle body from memory - just have a quick nose under the pedals to see if there is a cable attached to the back of the accelerator cable
Brad.
Post by Brad. »
Ah my bad, sorry Alex.
Read it on Clubpolo the other day. Oppsie
lol thats clubpolo for you :P
Brad.
Post by Brad. »
hahaha, i was reading on here that you've got a grill spare, wouldn't happen to be a GTi one would it?
