really annoying boot problem
rapid_f1
Post by rapid_f1 »
hi all the boot on my x reg polo will not open without using the key. i though once you open the driver door the boot should open by pressing the handle. whenever i want to drop someone off somewhere, i have to park up, take the key out the ignition, open the boot with the key. is this normal?
Re: really annoying boot problem
Does your car have central locking?
The boot lock needs to be in the | position on the lock for it to function on the central locking
rapid_f1
Post by rapid_f1 »
ahhh...my cl pump died and havent got round to buying another one yet.
so the auto boot needs the cl to work properly.
vw asked me for £220 for a new pump. is that about right?
my part number is 6N0 962 257. It has 8 pins.
that would explain it then.
Well, they are damned expensive.
Have you tried breakers yards, ebay etc? You can pick them up for far less on there!
rapid_f1
Post by rapid_f1 »
thanks for the info. i am at this minute searching ebay and there are ones on there that look simiar but they have slightly different numbers
mine - 6n0 962 257
them - 1ho 962 257
does it matter?
I believe other models can work - you need to ensure that the new one has the same amount of pins. Ive read somewehre that a mk3 golf one can be used!
rapid_f1
Post by rapid_f1 »
