damp headlining
benmkiv
damp headlining
Post by benmkiv »
any ideas whats causin gthis?
i have a 3 door 6n2 1.0
and the headlingin looks like its been wet and then dried again on the very far left on the passengers side by the window
any ideas guys?
dub6n2
Re: damp headlining
Post by dub6n2 »
sunroof? or damaged door seals?
benmkiv
Re: damp headlining
Post by benmkiv »
i dont have a sun roof ands its not near the door, only got the three door model its near the window but ive checked all the seal around that.
i was told it maybe the rear washer piping but i dont think that runs through the headlining?
red6n2
Re: damp headlining
Post by red6n2 »
it dosent it runs down the passenger side of the car, do you have a corroded areil base ?... that may be letting water in ?
Re: damp headlining
I was gonna say aerial - that could be a possibility.
benmkiv
Re: damp headlining
Post by benmkiv »
hmm its not the nicest looking thing,
hopefully if we have some nice weather i can take a look tomorrow,
or crap weather could help to assess the problem :)
thanks for the help and ill let you know
if not its just an excuse to reline the headlining :D
benmkiv
Re: damp headlining
Post by benmkiv »
i believe its the roof bar thingy if anyone else is having this problem,
n ot sure on a solve yet
Re: damp headlining
roof bar thingy?
red6n2
Re: damp headlining
Post by red6n2 »
i think he means the two slats either side of the car that you place the roof bars into...
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: damp headlining
Post by emma_88 »
red6n2 wrote:i think he means the two slats either side of the car that you place the roof bars into...
Aye, he means the roof strips/rails
Re: damp headlining
I cant work out how that would leak though - its a bonded part of the chassis. Best way to fix it (if it is leaking) is with something like tigerseal or a similar PU sealant as this will seal it up with flexibility for chassis movement.
red6n2
Re: damp headlining
Post by red6n2 »
i dont really see how it can leak either... id still say its most likely to a corroded or lose ariel base. or even loose door seals ?
Re: damp headlining
Agreed - the door seals touch the headlining, so it is possible it could be causing it.
Either that, or the windscreen seal has split.
Can you get a photo of the affected area of headlining?
benmkiv
Re: damp headlining
Post by benmkiv »
yeh i will do over the next couple of days
im pretty sure its not the aerial since it is not in the middle of the car just the left.
its only a 3 door so it wont be door seals
i will get a picture up asap
