Well, yes, I know all mk2 brakes are a little unnerving Problem is, mine are fine under anything up to moderate braking, and then the rear wheels just lock up. Apart from being somewhat dangerous, it's really embarrassing to come sliding to a stop just to give someone else right of way to pass a parked car I don't notice any problems at all under normal braking, and the brakes are plenty strong enough to lock all of the wheels if I need to (albeit with my full weight behind the brake pedal..).. brake discs and pads are a bit worn, but not worryingly so, and all of the tyres have plenty of tread left on them.. so I'm not quite sure what's up with it..
Always possible that through some incredible coincidence my rear wheels just happen to have been on a loose surface every time I've braked heavily, I suppose.. but I think it's more likely to be the car.
Thanks a lot for any suggestions you may have..
Unnerving brakes
- Sponsor
Either your discs are far more shot than your drums, or (and?) more likely, it's your rear brake balance compensator playing up. Either take a peek through the workshop manual (haynes, or whatever else you prefer) to see if it has anything on adjusting it, or nip down your friendly kwik fit/etc and get them to fettle it.
Cuz you dont want that to happen if you have to put out the anchors on a wet corner...
- Sponsor
- Sponsor
um........ apart from that bit im none too sure on brake issues..... if there's some way to slightly weaken the drums and strengthen the fronts? (or get those discs and calipers checked)
just hope its not a sign one of your diagonally opposed circuits hasn't failed or maybe overly worn rear tyres?
or p'raps its just a mk2 problem (wish someone else would jump in here and clear it up )
- Sponsor
Having been doing some rather extensive testing (driving like a madman ), I've come to the conclusion that I was just being a bit nervous about this.. it occurred to me that every time this has happened has been on a country road, usually loose mud etc all over the place, and it's always the nearside rear that locks up first, ie the one that's on the mud at the side of the road. So.. I think probably all I have to worry about is the fact that the brakes are shocking as standard
- Sponsor
