Hello new here,,just got a 6n2 w 2000 polo 1.4 16v s
Im wanting to fit fogs as its all colour coded and think it will set the front of--is the wiring already there for them behind the bumpers (i know i need the switch in the dash)
And im fitting an after market alarm,,but does this polo have a imobillizer as standard from the factory does anyone know?
will save me cutting in to ignition wire and fitting a relay if it has
thanks everyone
craig,,im form prestwich manchester,,hope to come on a meet if there is any in the future
Newb here,couples of questions,,fogs/imobillizer 6n2
Re: Newb here,couples of questions,,fogs/imobillizer 6n2
found the imoboilizer info out,,just getting conflicting info on the spot lights,,hopefully get change this weekend to check if the wires are there
Welcome to the forum mate
The 6n2 has a transponder immobilizer fitted as standard
As for the fogs, the wiring is all done. You just need to add the fogs and a new switch that supports front fogs.
Thanks for the help,I found the wires for the fogs,so im going to now hunt some down for a good price if i can
