Cupra bushes help
Cupra bushes help
My gti has just failed it's mot today due to the front rear wishbone bushes been badly worn. After reading up on here it seems to be a common fault so I popped to seat to buy some cupra ones. After getting home I think they may have sold me the wrong ones so wondering if somebody could put up a pic to put my mind at rest.
yorks GT TDI
- Sponsor
Re: Cupra bushes help
Cheers mate looks like he has given me the wrong ones as the ones he supplied me had cut outs in the bush. Do I need the cupra tdi ones then or the cupra petrol model ones.I just asked for the Ibiza cupra ones for an 06 plate thinking they would be right. The part number on the invoice is 1k0 407 183 E.
You want these ones pal
http://www.awesome-gti.co.uk/product.ph ... 6&xSec=267
And yeah your correct, its the Cupra TDI bushes you want.
WIll the above fit the polo 9n3 1.4 tdi 55 reg? been looking at these for a while but never knew which ones are the correct ones for my poloNMavs wrote:You want these ones pal
Cheers for the advice got the correct ones fitted now. Also got a set of four pirelli pzero and first impressions are not good. Hope they just need bedding in a bit. Not sure if they will fit a 1.4 but the old bushes look exactly the same as the girlfriends 1.2. I'm sure someone on here will put you right.
Am not entirely sure they will fit the 1.4 TDI. I had the 1.9 TDI Sportline, 58 plate and it had a completely different setup than my GTI. Rather than having this bush, it had two plates.
