Anyone camber shimed ther comps?
As above looking to pick up some cambershims, can anyone shead anylight on them, have any opinions, or have any pics
Nobody lol
Re: Anyone camber shimed ther comps?
I guess not :/
Im interested in these aswel... They are only like £18 from venom motor sports, might be worth a go...?
- lukey GTI
how will it effect handling ?
Well ive got camber adjustments on my front coilovers and ive adjusted them from -0.5 negative camber (Standard) to -2 negative camberlukey GTI wrote:how will it effect handling ?
![Smile :)](./images/smilies/icon_smile.gif)
I got a pic man?Mr Blobby wrote:Well ive got camber adjustments on my front coilovers and ive adjusted them from -0.5 negative camber (Standard) to -2 negative camberlukey GTI wrote:how will it effect handling ?you can just about see the difference but i did feel it alot more stable in the corners! I would defiantly recommend camber to anyone who can get it.
Also how does it effect ur tyre wear? Drastic?
I'll get one up Monday if I rememberdrennan wrote:Also how does it effect ur tyre wear? Drastic?
Still don't know how the shims work though... Anyone know that?
they fit between the drum or disc and the rear beam, they just push put the bottom of the drum or disc and the stub axel hence 'leaning' the wheel into the centre of the car.
i ran around 3.5 deg with a 1.5 deg shim and two extra washers on the bottom two screws
HTH
HTH
U got a pic matey?AdamR8 wrote:they fit between the drum or disc and the rear beam, they just push put the bottom of the drum or disc and the stub axel hence 'leaning' the wheel into the centre of the car.
HTH
Sorry I forgot to upload some pics. They aren't amazing because I have no poke on the wheels :/ But I hope you get the idea
The camber is set at 2.5 degrees negative i think ![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://i1083.photobucket.com/albums/j397/Mrl3lobby/IMG_0645.jpg)
![Image](http://i1083.photobucket.com/albums/j397/Mrl3lobby/IMG_0644.jpg)
