7x16 et23 with 15mm adapters?!
Moonska
Post by Moonska »
Has anybody run anything similar to this on the rear of a 9n?
After a quick mock up i think there will be too much poke :-(
Maybe a roll & flare might help haha
Its a 1.9TDi
Feel free to post some wheel porn
Cheers guys
chewy_
Re: 7x16 et23 with 15mm adapters?!
Post by chewy_ »
What are you running at the minute?
This will come in handy and tell you the difference
http://www.1010tires.com/WheelOffsetCalculator.asp
Moonska
Post by Moonska »
chewy_ wrote:What are you running at the minute?
Im still running standard sport 15x6 et43 at the moment, so its going to poke a lot more lol 48mm extra.
Its the adpters making them a et8 thats the issue.
The 6J fronts will be tight too i think. May have to have a rethink!
Nick
pip_polo
Post by pip_polo »
What wheels are they?
Moonska
Post by Moonska »
pip_polo wrote:What wheels are they?
Porsche fuch :)
Im building a 71 beetle and they were bought initially for the bug but they will be too tight on the brakes. So its either sell them or squeeze them on the polo.
pip_polo
Post by pip_polo »
Do it :-)
Bickerton
Post by Bickerton »
If you run a bit if stretch you'll probably be lfine, used to run 7x15 et13 on my lupo and was fine once arches were rolled, that was with 165/50r15 tho, ideally woulda prefered slightly wider tyres but woulda needed a little bit of.camber maybe
Bickerton
Post by Bickerton »
I am however running compomotive th Monos, 16x8 et25 with 195/45 r16 tyres
Whorage
This is my wheels vs your Fuchs both with same tyres
Hth
Moonska
Post by Moonska »
Cheers guys :)
BICKERTON - Cheers mate, only 4mm extra poke than yours then, are you running camber shims? What size are you running on the front? Im unsure what the offset of a 16x6 fuch is, but looking at it, thats prob going to be more of a problem than the rear.
If they will work, deff a future plan :)
Ive just had 4 new tyres so will wear them first i guess.
Bickerton
Post by Bickerton »
Nope, no camber shims and the arches are untouched other than bending back the brackets on the front arch liners
chewy_
Post by chewy_ »
get some 165/45/16's on http://tyrestretch.com/7_165_45_R16/
:wink:
