Blue GT MFD Second Speed Display (mph or km/h)?
nigelibrown
Post by nigelibrown »
Taken delivery of my Blue GT and need to know how to change the Second Speed display from km/h to mph. In the manual it states selecting a menu Alt. speed dis in settings. This menu option is not available on the Blue GT? And the alternate method of setting it does not work either.
vedubber
Re: Blue GT MFD Second Speed Display (mph or km/h)?
Post by vedubber »
The option isn't available. As the speedo doesn't have a KPH display.
The only option is VAGCOM but currently the option to turn on the large MPH doesn't work for new cars.
Joe9n3
Post by Joe9n3 »
You need vcds
Change cluster to australian
Then on the mfd un-check alternate speed (option will have moved to main screen)
Then enable Digital Speed (mfd data iirc)
My dealer didnt want to do this so i bought a cable and did a few things myself!
vedubber
Post by vedubber »
So far on my car it appears this function has been disabled tho.
phill_11
Post by phill_11 »
I had this briefly attempted yesterday but it would appear this option is now locked out. If someone has successfully done this on a 2013 vehicle then please advise how it is done?
b0rk
Post by b0rk »
Rosstech advised me the function has been locked out on the newer clusters along with needle sweep.
Immlang
Post by Immlang »
Joe9n3 wrote:You need vcds
I followed your advice and found it worked a treat. Many thanks. I used a Ross Tech dongle.
I've just bought the BlueGT - still has less than 100 miles on the clock. Very excited.
While I was at it I activated auto door locking at 10 mph.
Norbreck21a
Post by Norbreck21a »
b0rk wrote:Rosstech advised me the function has been locked out on the newer clusters along with needle sweep.
Well the wife's Blue GT is only 2½ months old, and her's allowed it ?
Large Digital Speedo
AGE_0301 by Sootchucker, on Flickr
Needle Sweep (Staging or Celebration Mode)
AGE_0306 by Sootchucker, on Flickr
vedubber
Post by vedubber »
Did you do this via the post a few above about changing the cluster to Australian and doing what it said?
vedubber
Post by vedubber »
Did you activate this as per setting the clocks to Australia in the post above?
Norbreck21a
vedubber wrote:Did you activate this as per setting the clocks to Australia in the post above?
No, changed it to ROW (Rest of the World), as I did with my Scirocco. The celebration mode (needle sweep), was done without having to change anything in the coding.
