My wifes 98 1.0L suffers from a fast idle (approx 1500 rpm) which drops to normal after approx 20 seconds.
I have removed the throttle body to clean and noticed oil in the air filter housing. The oil level on the dipstick was too high so I dropped about
0.5 L. The crankcase breather pipe is damaged but doesnt appear to leak - I have ordered a replacement from vw. It appears to be difficult to remove from the crankcase.
I bought a new water temp sensor from GSF today but it is different to the origional and doesn`t fit as well - leaks if moved slightly. It has a metal end and the only way it fits is to fit the sealing ring against this metal end, held slightly loose by the circlip. I cannot make use of the yellow ring.
The idle is slightly better 1200 rpm dropping to normal after 15 secs.Will the ecu adapt to this new sensor?
Any help would be much appreciated.
Dan
