First 1k Miles - Engine break in
- Drives: 6C SE - 3 Door - 1.2 TSI - Deep Black
Hi there,
So after the longest wait ever i'll be picking up my 6C on Sunday 1st March, Horay!
I've read from some sources that the first 1k miles should be taken easy as the engine is breaking in etc which is completely understandable and the view that I would take.
However i've also heard some contrasting views on this stating that newer, modern engines don't usually need this sort of treatment.
What did you guys do? Take it easy or kick its head in? hah.
- Drives: 2015 Blue GT
Re: First 1k Miles - Engine break in
Got mine 3 weeks ago. Been taking it easy 99% of the time (2/3 - 3/4 throttle max) and then gradually feeding in the higher revs (>3500) once the engine's nice & hot. A bit like making love to a woman, really...
Hhah. Cracking analogy that.
Yeah for sure that's exactly what I had planned too. Feel sorry for the engines at the mercy of owners who just don't really care!!
- Drives: 6c Polo Blue GT
It does recommend in the owners manual to run the engine in for the first 1000km or so at no more than 2/3rds of top engine speed and from 1000-1500km to gradually increase driving performance to top speed and highest engine speed.
When I got mine I was told to take it easy for the first 1000 miles by VW
Yes - although the new engines are already 'bench run in', it is no substitute for real world running in, so being respectful on engine and brakes for at least the first 1000 miles will stand you in good stead.
I don't believe in driving the car hard from the off.
- Drives: 2015 VW Polo SE and 1972 GT Beetle
Best to take it easy for the first 1000 miles just to bed parts in. On my first 59 plate 6r the gearbox failed spectacularly at 1200 miles on the M69. The 12 plate and the new one have been treated gently at first.
- Drives: 2015 GTI
i waited until the oil was up to temp in my 2007 gti to give it the beans and i'll be using the same technique in my 2015 gti lol
Cheers for all your help, much appriciated!
- Drives: 2020 polo gti plus
I bedded mine in for 2000miles, but I was told by VW that as long as it's up to temperature it doesn't need a bedding in period. They said that parts are so accurately made these days they don't need to be bedded in. Make of that what you will!
Please be aware that if you are too gentle with your new engine your cylinder bores may well glaze causing insufficient compression and even excessive oil consumption. I'm not one of those who believes you have to thrash an engine from new to bed it in but it's good procedure to make sure the engine does have some load through the rev range otherwise you may end up with an under performing and oil thirsty motor
I've bedded a few brand new motorcycles in, and what I did was to use the torque of the engine and not be scared to go up past the mid range/revs of the power (obviously not revving it in to the higher range). Slowly increase this over the course of running in and don't be scared to have the odd blip through the gears using the torque.
If you saw the procedure the factory used when testing the new engines before the cars go out to the dealers you'd cringe
@Daveb73 - I couldnt agree more with your reccomendation. I have the same beliefs that tickiling it along for 1k miles will do more bad than good and you have to give it at least something but not everything, all of the time.
I plan to use the tourqe to the best of its ability but I'll not be letting it run anywhere near full RPM until theres been healthy usage.
- Drives: 2015 blueGT
So I am aware, as I get my BGT in May, it's best to basically rev it sometimes just not all the time for the first 1K or so?
Just make sure you use the power (torque) through the gears, don't rev too high obviously, but 'drive' the car, don't wrap it up in cotton wool. As I said in my previous post, it's a good idea to give it a quick blip through the gears every few journeys, drive it briskly using the torque and don't be scared to let it rev a little higher now and again, especially in the lower gears.
Enjoy
Enjoy
