Intermittent Limp Mode and Engine Management Light
IZVVC
Post by IZVVC »
Hi guys I've been deal with an issue with polo for a few months now, but it has got worse over the past couple of months.
Basically, sometimes ill just be driving normally, then my car will go into limp mode, with a beep sounding, the ECU light and the traction light coming on, then my car really can't accelerate. I then have to turn the car off, and turn it on again and the lights normally clear the first time if not, it will clear on the next restart try.
After that sometimes the engine management light will stay on and eventually disappear after a day, or sometimes it won't come on after the limp mode, it really just picks and chooses.
It hasn't really affected the performance of the car except obviously when it is in limp mode, and I feel like when the engine management light comes on the car feels alit bit rough with jolty acceleration.
I then paid someone to do a VCDS scan and this is what has come up.
Can anybody make any sense of this, or advice what I need to do next, really love my polo, but this is really bringing me down. :? :(
Wednesday,27,May,2015,21:26:23:24971
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WVWZZZ6RZCY500896 License Plate: LO11 XGS
Mileage: 59900km-37220mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: WVWZZZ6RZCY500896 Mileage: 59900km-37220miles
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 1110
Address 01: Engine (J623-CGPB) Labels: 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 8949
Revision: -------- Serial number:
Coding: 00110016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001007
ROD: EV_ECM12MPI02103E906019A_VW25.rod
VCID: 2E53142D7176CE51CC3-807B
5 Faults Found:
11001 - Throttle Body (J338)
P1559 00 [032] - Fault in basic settings
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 59647 km
Date: 2015.05.20
Time: 14:53:12
13628 - Throttle Actuator (J338)
P1564 00 [172] - Under-Voltage during Basic Setting
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 4
Mileage: 59647 km
Date: 2000.00.00
Time: 00:00:00
10519 - Throttle Valve Actuator Control System
P2101 00 [096] - Malfunction
Fault Priority: 2
Fault Frequency: 1
Mileage: 59902 km
Date: 2015.05.27
Time: 21:13:12
10516 - Throttle Valve Actuator Control System
P2101 00 [232] - Malfunction
Fault Priority: 2
Fault Frequency: 9
Mileage: 59866 km
Date: 2015.05.26
Time: 19:14:37
10484 - Throttle Actuator Control Circuit
P2100 00 [172] - Open Circuit
Fault Priority: 2
Fault Frequency: 7
Mileage: 59647 km
Date: 2015.05.20
Time: 14:53:13
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3216D00B2C42D24EB84D700801300
VCID: 071D8189B24CBF192F5-8052
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 0
Fault Frequency: 39
Reset counter: 27
Mileage: 58558 km
Time Indication: 0
Date: 2015.04.17
Time: 13:25:29
Hex Value: 0x0000
Hex Value: 0x0002
Hex Value: 0x1107
Hex Value: 0x1389
Hex Value: 0x0088
Hex Value: 0x7F7F
Hex Value: 0x84F9
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326B005D6D4EEAB1A8B-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 144111599
Coding: 3CB029BF08A1000000200C002D2B0CD00040410F60060000200000000000
Shop #: WSC 12469 483 00190
VCID: 45814B81CCC06D091D9-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1621
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 1621
Coding: 08BC30
1 Fault Found:
00967 - Left Turn Signals
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 253
Mileage: 59512 km
Time Indication: 0
Date: 2015.05.13
Time: 21:09:01
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01X H09 0020
Revision: -------- Serial number: 003GX00MY90V
Coding: 003158
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B78BDEDDE8271F0B-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405L0HM7871ID
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB40630HM78A8RG
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB404R0HGJ6KHHB
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB404P0JE3GA9NZ
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 H HW: 6R0 920 960 H
Component: KOMBI H03 0505
Coding: 440A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3A7B287DBD3E12F160B-806F
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002100
VCID: 70EFCA55A3C298A19EF-8025
2 Faults Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 246
Mileage: 59256 km
Time Indication: 0
Date: 2015.05.08
Time: 21:39:01
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 201
Mileage: 59256 km
Time Indication: 0
Date: 2015.05.08
Time: 21:28:03
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADBD83D8D1E6271D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660039823
Coding: 010000
VCID: 2959E7314098A969191-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6D0929EA7CC759C75-807A
Address 56: Radio
Cannot be reached
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 02:42)------------------------
Re: Intermittent Limp Mode and Engine Management Light
Throttle valve VW Ref. 03D133062F Engine (J623-CGPB)
https://www.google.es/search?q=03D13306 ... 66&bih=643#
01165
http://wiki.ross-tech.com/wiki/index.php/01165
Cleaning throttle valve module -J338- Very important
http://workshop-manuals.com/volkswagen/ ... dule_j338/
First, check the connector, clean the contacts with https://www.google.es/search?q=clean+re ... ct+cleaner
IZVVC
Post by IZVVC »
Thanks Ciclo! :mrgreen:
Do you think I should clean the throttle myself, and do you know how to actually get it off?
Also what connections do you think I need to clean?
IZVVC
Post by IZVVC »
https://www.youtube.com/results?search_ ... ottle+body+
It is very easy, but if you have no experience, you should trust this job to a workshop or dealer. :wink:
IZVVC
Post by IZVVC »
Thanks ciclo :mrgreen:
but I know how to clean the throttle but you told me to check the connector and clean the contacts, which connector are you talking about?
And also do you know how I actually remove the throttle body?
thanks a lot in advance :D
Open the bonnet. :lol:
And look at the intake throttle briefly. :roll:
Ask yourself this question. Am I able to disassemble the throttle valve with the tools I have?
If the answer is yes, proceed as follows:
Release electrical connector, clean the contacts (plug and socket connector).
There is only one connector which I think you have not yet verified by the questions you ask me. :mrgreen:
Remove intake pipe clamp, remove intake pipe from the valve.
Remove four screws.
Remove the valve.
Clean the valve. (according Elsawin)
Install in reverse order.
Perform basic setting with VCDS.
Finished ...
If you still have questions about this issue after all the information that you have, I insist, better than the work be done by a workshop. :wink:
A small help for you to decide snugly, comfortably... Image
