2015 Polo SE Design, LED daylight lights
Scoopjeff
Drives: Polo 6R 6C0 2015
Post by Scoopjeff »
Hello all, new member here.
Ive just got myself a 2015 Polo SE Design and want to change the Daylight Running Lights for some bright LEDS. I've seen somewhere that I need canbus LEDs but I want to know how to get into change them??
Any info would be greatly appreciated including where to purchase bulbs.
Regards
Scoop
Re: 2015 Polo SE Design, LED daylight lights
pull the covers out of the bumper (just pull forward, not too hard) and you'll then see the light unit.
these are fixed with two torx bolts and you can then also pull the unit forward.
then you can simply twist (or pull, don't remember) the light bulb out.
Bigtam
Drives: Polo GTI 2016
Post by Bigtam »
Someone mentioned an old coat hanger in the small hole this does help as i done mine yesterday. Also when your replacing the fog make sure it goes back in the slot and clips back in then replace the 2 torx. Found link http://www.uk-polos.net/view ... 10&t=58286 :D
Scoopjeff
Post by Scoopjeff »
Brilliant thanks for the info. What bulbs did you use BigTam??
Regards
Scoop
Scoopjeff
Post by Scoopjeff »
Are they T20s?? Whats best place to order??
Bigtam
Post by Bigtam »
TheFrog
Drives: 2015 Blue GT
Post by TheFrog »
I fitted 60W LEDs in mine 6 months ago and, despite being warned on here that they might be too bright, I've yet to be flashed. They just look like normal 'bright white' DRLs to me.
Scoopjeff
Post by Scoopjeff »
I bought them ones Bigtam, however they weren't the right ones for my car. My Daylight Running Lights are next to the fog lights and are T20 7443 . Also just on a side note my car must be a newer build 6R 6C0 as my genuine VCDS doesn't pick everything up.
Bigtam
Post by Bigtam »
Yeah so are mine mate here is a pic not the best but just to show you Will take a better one later Image
