Still having problems with my brake lights, Ive replaced the brake switch and am still only getting the top light working, code reader is still bringing up the code in the photo. Are there any fuses or something I can check as other than that I'm out of ideas?
16955 - cruise/brake switch a circuit malfunction.
Brake light problems
Re: Brake light problems
There will be fuses to check but I couldn't tell you the numbers without checking
Also check you haven't got two blown bulbs - sounds silly but perfectly plausible. Also get a multimeter on the pins and check for 12V when activated
Zephyr
- Drives: 6N2 1.4 TDI Remapped
Turned out both bulb holders decided to pack up one day after the other lol
