Engine Pinking
vanmaster26
Drives: 1200 tdi bluemotion
Engine Pinking
Post by vanmaster26 »
Hi Everyone, thought i would ask the people who know, just recently bought a 2011 Polo 3 cyl 1200 tdi for the Wife that pinks badly until warmed up is the norm
Many thanks Kevin
Ricmondo
Drives: Polo Blue GT
Re: Engine Pinking
Post by Ricmondo »
I'm sticking my head above the parapet and expecting to be shot down but pinking, pre ignition, is restricted to spark ignition engines. Diesels can, at times knock in a way that loosely mimics pinking, it is more prevalent when the engine is cold. It could indicate a problem with injection pump timing or failing injectors.
The fewer the number of cylinders the more obvious the problem may seem, not so many cylinders to disguise the problem I suppose.
Re: Engine Pinking
I seem to recall reading that this can be caused by a faulty injector loom on this specific engine
vanmaster26
Re: Engine Pinking
Look's like i need to contact VW and see if there waw a recall then
many thanks
Kevin
