Hellooo
Me again.........
I have foglights fitted. or at least what i think are fog lights.
BUT
There is no option on the light switch for front foglights.
My car is a 2015 6C se
My mum has a 2016 se and it has the front fogs on the switch
James
Fog Lights fitted but no front foglight option on switch
Shappers01
- Drives: Polo Highline 1.0 TSI 81kW. R-Line
Re: Fog Lights fitted but no front foglight option on switch
Have you tried pulling the switch out on the sidelight position?
yes and it operates the rear foglight
James
James
cheba
- Drives: Polo R WRC 2014
Some Polo 6C only have the DRL, no foglight, in the lower bumper light. When I look up the part number of the one without foglights and look at photos, it looks similar to the one with foglight when looking at it from the front (it has dummy foglight for looks only). On the back of the housing however, the hole for bulb is plugged. I'm guessing your car has these light units with only DRL and no foglights. If you can take one of the lights out of the bumper you should be able to confirm this.
Can fogs be retrofitted ?
James
James
joe6
Yes they can viewtopic.php?f=56&t=71768
You can get light switches with both rear and front fog light positions from the internet. You will need a wiring diagram to locate the correct wiring points.
Awesomejoe6 wrote: Thu Jan 31, 2019 6:23 pm Yes they can viewtopic.php?f=56&t=71768
