Oh No! The starter motor!
tom16v
Post by tom16v »
whilst enjoying a quiet drink down the pub on sat i came out to go to a bbq to find my car would not start! after pushing it down the road i managed to bump start it, which is all gud apart from the fact each time i turn the engine off, i have to push it! took it 2my audi technician mate on sunday n the starter motors gone! the car's only a 2001 n i thought this was a bit soon,anyone else had this problem?
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
thats very unusual to happen to a vw polo anyway! let alone a 2001 reg, strange, maybe a design fault?
have you got it fixed now?
hope everythings ok with it
-Ben-
tom16v
Post by tom16v »
i had a new starter motor fitted on tuesday, but the car still doesn't start. but as it seems to be an electrical problem with the starter motor a fuse might have blown as well so i'm gettin that checked later 2day n hopefully it'l be sorted! and no more pushing! :)
tom16v
Post by tom16v »
problem solved! was a faulty connection in the ignition switch which caused the problem wit the starter motor,hopefully its all fixed now though!
polopowah
Post by polopowah »
glad to hear
nothing worse is there, when your motor doesn't start!
-Ben-
zahir_213
Post by zahir_213 »
yeh mate ive got that problem, i usualy have to smack under the streering wheel a few times to get it going, what part did you replace exatcly? part numbers would be helpful mate,
AshLeMacq
Post by AshLeMacq »
Same happened to mine on the day I bought it!
New ignition barrel later and everyones happy.
tom16v
Post by tom16v »
i havent got a part number cos i got the motor from an independant garage (cheaper) but the ignition barrel will prob need replacing in the future as that was the source of the problem! at least my car's not the only one wit this problem!
JWC
Post by JWC »
You should know that the barrel is the no.1 cause of problems on the 6N2. Its amazing to think, because they have been making that type for a long time, at least 6 years.
If you look at the common faults sticky, you'll see what I mean. Be nice to your barrel, always use the key the same way round and if the steering lock is engaged, be very gentle to disengage it without raunging the key.
