My car usually didn't came with fog lights in the front bumper, so the seller retrofitted it in a bad way. I can tell by the wiring he did.
So I've removed all the wiring and now, I would like to use that fog lights as a DRL. As far as I know, I need a DRL module like attached below but according to this schematic, I have to connect this yellow cable to the low beam cable in the engine bay to allow the drl to turn off when the low beam is turned on. But I have no way of knowing which wire controls the low beams and I'm not sure if there is only one cable controlling these low beams. so I'd like to know if this cable has a specific color ?
It should look like this :
