Goodday everyone,
Since the project steering wheel has been completed, I want to delve into a reversing camera that is in the emblem.
BUT! since I have an RCD310 radio I cannot use it on that.
Now I want to replace the radio it contains with an Alpine radio (ilx W650bt).
So I'm curious if anyone has experience connecting a reversing camera to an aftermarket radio.
I don't have a camera against that either, so it still has to be purchased.
Now I have found the topic of iichel's polo.
And he has put in his TS:
OEM 5K Golf 6 / T6 badge rear view camera Highline -> 5K0827469H + 7E0907441 + wiring
I hope there is someone who has experience with it,
And who can confirm me if the item number mentioned above can work.
I'm curious!
Reversing camera on aftermarket radio
Re: Reversing camera on aftermarket radio
It's important to match the camera to the needs of the radio in terms of the connector.
This is what to look out for:
26-pin = 4 wires for the video = sRGB (mostly OEM)
yellow tulip = composite = 2 wires for the signal (mostly aftermarket)
If you have an RNS/RCD, you need the 26-pin plug (OEM camera or ali + converter)
If you have another radio that needs a composite video signal, like a composite connector, you need a camera to suit that.
The camera you mention, the one I have, is an OEM composite camera that connects to a module. The module then sends out a differet signal (sRGB) to my RNS.
you radio looks like this:
I'd suggest a composite camera so you can connect it to the yellow tulip connector.
My camera can do that, with a small plug inbetween just for the shape of the connector.
Otherwise an aliexpress logo camera will do the trick as well. Or a camera in the license plate light/bumper.
