cosmonaut08
Posts: 4 Joined: Sun Jan 10, 2021 4:19 pm
Drives: Polo GTI '16
Post
by cosmonaut08 » Sun Aug 15, 2021 10:25 am
My 6C GTI '16 manual started making weird noises at around 3k rpm. What could this be?
[youtube]
https://youtu.be/Dquu4OS0yr8 [/youtube]
[youtube]
https://youtu.be/Bjm7NTvR1qQ [/youtube]
It does it in 1st, 2nd and 3rd. I don't think it does it in higher gears. Or I can't hear it at those higher speeds
The noise is mechanical. It's almost as if something that's spinning is in contact with something that isn't.
It doesn't happen all the time, but it tends to do it under load. For example, it does it when going up the hill (without flooring).
It starts and ends at around 3k rpm.
Weirdly enough, I haven't heard it do it during shorter journeys when it hasn't warmed up properly.
No other side effects or issues apart from the noise. The car still pulls well.
The car has done 64k miles, serviced this week. No performance or suspension mods have been done to it.
TrebleTA
Posts: 185 Joined: Thu Jul 02, 2020 10:03 am
Drives: 2021-22 GTI+
Post
by TrebleTA » Sun Aug 15, 2021 12:02 pm
That is a strange one, if your idle in the car and rev up to about 3k do you hear then, if not will be gearbox maybe, is it manual or auro
cosmonaut08
Post
by cosmonaut08 » Sun Aug 15, 2021 3:27 pm
It's a manual and it doesn't do it when revving it up in neutral. It doesn't always do it when flooring it either which is odd.
TrebleTA
Post
by TrebleTA » Tue Aug 24, 2021 10:54 pm
Any update, did you get it looked at?
