Polo GT ride height for Tow Bar
Sabs
Drives: 2015 90hp 1,2L TSI comfortline BMT 6C
Post by Sabs »
Hi everyone,
I have a 6C 1.2 tsi with steel wheels, and the standard factory ride height. I've been looking at getting some alloy wheels and maybe lowering the car to the GT height, but I have a trailer hitch on the back and I want to make sure that lowering the car won't give me problems when I tow a trailer. I've had some loads last time I was moving that really brought the rear end down, and just wanted to know if anyone who has a lower car, or a GT has ever had any issues with wheel rub when using a trailer.
Also just curious what your ride height was. I've read on another forum that the ride height for the GT according to the technical specs is 351mm+/-10mm for the front and 367mm+/-10mm for the rear (from wheel arch to centre of wheel.)
thanks all!
Re: Polo GT ride height for Tow Bar
you should never exceed the maximum allowable weight on the trailer hook.
in most cases it's 80 kg/ 160lbs
If you don't go over this, the effect of a trailer should be about the same as a grown adult standing on your trailer hook.
Sabs
Post by Sabs »
I'm pretty sure I'm not going over the weight, seeing as I can lift the trailer by hand to put it on the hitch, I'm not pulling boats or caravans, its just a small cube trailer from the hardware store... anyway I just want to be sure I can lower the car some and not have any issues, so thanks for the advice, but it wasn't super helpful to my question.
sabs
