Does Anyone know how to make the polo open all the doors with one press of the unlock button only?
It’s a 2011 polo gti without mfsw.
John .
Door locking
Joemaxi531
- Drives: 2011 Polo Gti dsg.3 door.
Re: Door locking
Yes, it's a simple coding of the BCM with i.e. VCDS, OBD11
Tracendaz
- Drives: 1.2 Tsi SE 5 door
Re: Door locking
My Polo is a 2015 with the infotainment screen and I used the menu on that to select the "one blip unlocks all doors" setting to match the non-variable setting on wife's VW up!.
Apologies as I don't know whether your Polo has the infotainment screen or not.
Kind regards, Tracendaz.
Joemaxi531
Re: Door locking
There is nothing in the infotainment screen relating to that.
My son has vcds I’ll ask him to bring it over
What modules have to be changed ?
Re: Door locking
You will need access to VCDS or OBDeleven as said earlier, your car has a different set of "electronics package" to the later 6C Polo, so I'm guessing that you would need to look around in Central Electronics controller, ie controller 09 - I'm guessing that from looking back at a scan from my daughter's previous car which was a late 2009 SEAT Ibiza - so a car very closely related to a 6R VW Polo.
Joemaxi531
Re: Door locking
Will get that done
Will get that done
Re: Door locking
Good, though as said earlier Central Electronics is also BCM - Body Control Module, I thought that a quick "look" using Google would guide you into which Byte and so Bit(s) that needed altered.
I'm sure that info will exist online if you try harder than I did earlier, VCDS does include "help" when sniffing around in controllers.
Joemaxi531
Re: Door locking
BCM-> Selective door unlocking
