Many thanks
6C GTI battery
6C GTI battery
Hi, will I need to get the battery reprogrammed if I disconnect it to stop the air bags going off when I remove my seats. Attempting a fix at heated seat element
Many thanks![Image]()
Many thanks
giannis20vt
Re: 6C GTI battery
CMacD7 wrote: Wed Apr 19, 2023 12:43 am Hi, will I need to get the battery reprogrammed if I disconnect it to stop the air bags going off when I remove my seats. Attempting a fix at heated seat element
Many thanks![]()
No, you don't need to do anything after disconnecting the battery. All you have to do is "play" with the power window switch to restore automatic mode.
