Schrader valve for AirCon
ccarmock
Post by ccarmock »
Hi
I wonder if anyone can advise me of the correct part number for a replacement schrader valve for a 2007 VW Polo 9N3 please? This is for the low pressure side.
I have seen reference to a part 8E 08 20855 then a reference to this being the right part for the 2014 onwards model.
Any help appreciated
Re: Schrader valve for AirCon
I've had a look at the parts listing, but it looks like you need to buy the complete valve housing with insert - and obviously a new O-ring seal, but I'm guessing that you are only needing to buy a new Schrader insert.
So maybe make contact with a local AC proper fixer, I seem to remember looking into this many years ago - for a 2000 VW Passat 4Motion and finding it was different thread sizes for the Lo and Hi side port inserts.
ccarmock
Post by ccarmock »
Yes I just need the valve insert. Certainly the housing is a different side on high and low side so assume the high side valve is different also.
