Hi all,
I’ve just got a Polo 9N3 GTI 2006, and the ESP light is on. The fault codes are:
Code Meaning
00493 ESP Sensor Unit (G419) fault – the module is reporting a communication or functional error.
02892 Supply voltage fault to ESP Sensor – the sensor isn’t receiving proper voltage, ground, or power is interrupted.
I’ve been trying to locate the ESP sensor to replace it, but I can’t find it anywhere. Online guides suggest it could be either:
on the steering column, or
under the centre console.
I’ve checked both locations thoroughly and even removed trim and carpet, but still can’t locate the sensor.
Can anyone advise exactly where the ESP sensor is mounted on this model? Any guidance would be greatly appreciated.
ESP sensor & 00493, 02892 errors Codes
CarbonChaos
Re: ESP sensor & 00493, 02892 errors Codes
AI suggests this ,
The G419 sensor is known as "Combi sensor for acceleration and yaw rate For vehicles with electronic stabilisation program -ESP- " and is VW part number 6Q0 907 637 A, the current retail price is £1044 inc. VAT It is located "next to left seat cross member in floor panel" .
More than the cars worth
