Do you have to drill a hole from the engine bay?
PeteM
Post by PeteM »
to get wires through? or is there a hole?
Speedlaw
Moderator
Post by Speedlaw »
I fed my power cable through the hole in the bulkhead that's got all the regular wiring-loom-wires going through it, there's just enough room to squeeze one extra in there. Saves drilling!
david burton
Post by david burton »
no don't do any drilling! there should be a few places - I did a bit in the DIY section on how to wire it up....
LJ_87
Post by LJ_87 »
i ended up drilling a hole on the passenger side and driver side, but the driver side is easier if you are as the pollen filter and you need to remove a good bit of the dash are on the passenger side :?
david burton
