I am thinking of buying a new headunit after xmas and i will need some decent speaker cable for my rear speakers.
Can anybody recommend a decent type of cable and headunit, i have had a look on the car audio direct website and had a look at a few bits, are these any good?
Headunit
http://www.caraudiodirect.co.uk/product ... ts_id=3521
Speaker cable
http://www.caraudiodirect.co.uk/product ... ts_id=1853
thanks in advance guys and gals
headunit+speaker cable
I havent' like used every single headunit in the world so I can't really say much about this particular one. So you might be better off to search for reviews on the net.
Blaupunkt should be okay with their standard quality - German manufacture. But if you asked me?
Alpine mate.
Well that cable looks alright - "looks" and should be okay. I wouldn't spend more than like £3-4 jus on speaker cables. 'cos I'm jus using some "standard" non-branded technical ones - which still works fine and does the job.
But if you're looking for ultimate quality in terms of look + power than you could get that or some even more expensive/better ones. They should be better if you're running high powered speakers.
But it should be adequate enough for most normal 100~Watts applications.
Hope it helped.
Alpine mate.
Hope it helped.
