Brian Barkclay (top bloke)
![Cool 8)](./images/smilies/icon_cool.gif)
Prolek
www.prolekglasgow.co.uk
tel - 0141 5580302
clear fogs -158.08 per pair
black fogs - 239.28 per pair!
Try giving him the part number off ETKA please!
He did two sets of clear fogs + free relays and better bulbs (well bright) for 138.65 each (both me and robz paid 138.65 per set).
not cheap but alot cheaper than vw.
Six nuts and bolts with hex locating lugs on shaft were 17.19 from vw
A got all this last April (04).
I had to wait 2-3 weeks but as hella have to dig out the moulds to make new sets as there are none lying on shelfs in germany. Only bit you have to get from vw is the mounting bolts.
Hope this helps - you should mention that I got a set of two for me and robz for our polos might help him remember.
Mine are wired up with a relay and work of the existing dash switch. My grandpa (an electrician all his days) made up a set of wiring diagrams and a took lots of pics when a fitted mine if anyone is interested.
the wiring diagrams give lots of different options -
fogs on with dip,
fogs on with dip or full beam,
fogs on with full beam (also when you flash the lights) etc etc
each time you want extra stuff it is one extra wire each time basically.
Also if the fogs are to expensive he does other hella lights wich fit the bumper recess, as well as the rarer square and round fogs or spots for grill instalation, have to buy a new grill from him too.
Final point a think Karl might be after a set if any one else is wanting them let him know, might get a better discount than I got!!!
cheers Richard
