Removing seats from a polo 9n
drshah
Post by drshah »
cheers mc_iver
drshah
Post by drshah »
hi,
i tried removing my seats today. i was expecting the 4 screws in each seat rail to be a torx screw. on inspection, they were some weird 12-pointed star instead of the 6-pointed star torx screws.
i was confued, so i went to halfrauds and i bought a t50 torx driver. i tried it in the 12 pointed screw recess, and it removed a few of them.
on some of the screws however, the torx bit is just spinning in the recess. it is shredding the 12-pointed star to bits. now to prevent the screws becoming completely useless, i stopped removing the screws.
WHAT TOOL DO I USE TO GET THE DAMN SCREWS OUT. i could not find a 12-pointed bit anywhere!!
PLEASE PLEASE HELP!!! i am really p*ssed off right now!
daa709
Post by daa709 »
I think the 12 star ones are called spline tools. They are technically the same size though, it may only have 6 stars but they will still fit. (the same goes for pretty much every torx in a vw!
drshah
Post by drshah »
thanks but i am still looking for help with what bit to use to get these nuts out. IF i continue to use a torx bit, i will shred the pattern inside the nut, which will really mess things up coz then i'll never be able to get them out!!
did everybody here remove the nuts using a torx set? what size? any ideas please. i have my seats half off and my car is out of commision until i fit the new interior
Hamish
Post by Hamish »
why not just use the right size torx bit, because you quite clearly havent been or it wouldnt have chewwed it up :?
poloecosse
Post by poloecosse »
there not torx there spline, just go out and buy a cheap socket set and make sure it has spline sockets in it
pidge87
Post by pidge87 »
You will need a set of XZN bits to remove them properly :)
Careful when putting them back in though, the bolts are hardened steel and the captured nuts in the body of the car are mild steel = easily cross threaded :?
Due to the nuts being captured as well once they are fooked theres no way of egtting them out to replace them :!:
drshah
Post by drshah »
thanks pidge. Yep they were XZN nuts, made of a very soft metal, and so if u use a torx bit it can really shred the pattern. the 12pointed star is also called a triple square. went down to my nearest parts place and bought the bit for £3. then i did the job properly!!
thanks for the help lads
