Heater plugs fuse!!!!!!!!!!!!
werna
Post by werna »
can anyone help me??? my polo 1.4tdi is having trouble starting :( theres no power going to the heaters and ive been told its a common fault on them for the fuse to go but i cant find the fuse :? can anyone help me please????
alexperkins
Site Admin
Re: Heater plugs fuse!!!!!!!!!!!!
Post by alexperkins »
I presume you mean glow plugs and not heaters?
nick6n2
Post by nick6n2 »
polo tdi's often dont even use the heater plugs to start the engine unless its below a certain temperature not quite sure wat it was 6 degrees or sumet so oftens the case you dont get power to them cuz the atmospheric air is enough to warm up once compressed in the bore by the piston so you might not be looking at heater plugs for your fault here, let us know how you get on.
nick
werna
Post by werna »
there is no power at all going to the glow plugs when the ignition comes on, the glow plug light lights up on the dash, but theres no power going to the plugs themselves, we have put a switch with a direct feed to the battery and it did help slightly but then stopped working?
problem is, everytime i get into it it takes f****n ages to start, jus makes me look silly when im there for agggeeesss waitin for it to catch?
anybody got any more ideas??
nick6n2
Post by nick6n2 »
whats it run like when it is running any problems or difference?
nick
alexperkins
Site Admin
Have you plugged it into VAGCOM or similar mate? If not, I'd strongly recommend doing so as it will help you out
werna
Post by werna »
it runs exactly as it should do when its started, just takes a while to start it!! yep iv plugged it in at my dads garage and nothing came up!! all i need to do is locate the fuse for the glow plugs which i cant find, anyone got any ideas???
alexperkins
Site Admin
Fuse number 23 its a 5 Amp mate
