I sincerely appreciate both of your comments,
rorybrks & anto08445, it’s great to get such good insights without having to pay for them...
Regarding fog lights with SCLs (Static Cornering Lights):
There are several possible scenarios, but to summarize, the main ones are:
1 Fog lights + SCLs in the fog lights = SB57 fuse (T73b/11).
- With an 'electronic' AUTO light switch (T10), or with a standard (non-AUTO) light switch (T17).
- H4, H7, and 6C LED headlights.
- The type of BCM -High or Max- depends on the installed equipment.
2 Fog lights + SCLs in bi-xenon headlights = SB54 fuse + SB57 fuse.
- Bi-xenon/Bi-LED headlights.
- BCM Max.
3 Fog lights only = SB54 fuse (supply from T17/8).
- H4, H7.
- Any BCM,
Now, the automatic light wiring that I manufacture, with a fog light relay,
covers all the possibilities where it will be installed.
Let's say it was designed to be universal.
The fog light relay is not necessary for option 1, but it is still a double electrical protection for the
'electronic' AUTO light switch, it doesn't hurt to have it installed, although
there is no problem that the T10/5 signal connects directly to T73a/7 without this relay (let's say it's a factory design with asterisks because the only official diagram that exists for 6R is the one I made
Therefore, anto08445, answering your question, of course it is possible.
