beeping oil light is doing my ******* head in
adummy
Post by adummy »
my oil light is still beeping at me
i changed the switch and it didnt do anything :shock:
today i disconnected the sensor and the oil light stayed on. i heard this could be a ground fault? is it?
and i know that oil is gettin to the engine cause took the cap off and can see it and after a quick test run there was oil at the top of the cap
also is there a second pressure switch on polos? i changed the one on the block but i have seen them on oil pumps before aswell
paulzpolo
Post by paulzpolo »
have you checked the oil level? may be too much oil
on some vw/s if you slightly over fill it this will also set the beeper off, it does on my transporter,
adummy
Post by adummy »
oils where it should be mate im always checking it
also the oil light never comes on while idle and the temperature is always fine
its really starnge :?
does anybody know roughly how much a 1.4 16v oil pump is? cause cars dont fair amount of miles and im goin to replace parts that are always in constant use soon
Have you had it plugged into vag-com...until youve done that, you might end up replacing things whilly nilly as it can be many things which brings that light on.
adummy
Post by adummy »
how much is a vagcom test?
and do i have to get it done at dealership?
Any VW specialist should be able to matey. VW charge a fortune. There may be someone with it locally on here :)
adummy
Post by adummy »
kk thanks i know a couple of vw speacialist mechs round by me so ill ask them
thanks again for the info
No prob mate ;)
