☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
ivanv
Drives: 6R 75 hp 1.6 TDI
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Post by ivanv »
Hi ciclo,
I have made a separate post with an introduction viewtopic.php?t=80126, sorry for spamming that thread.
I wish you a great day.
Best Regards,
Ivan
Thanks, I've subscribed to your thread.
See you there.
Polo6r2014
Drives: Polo 6r 2014
Post by Polo6r2014 »
Hello, I'm new here. I wanted to ask if the conversion kits for automatic headlights are still available? I have a 2014 Polo 6R.
Hello Polo6r2014,
Yes, they are still available.
I have sent you a private message with my email address so you can ask me anything you need to know, please check your inbox. Thanks.
yassinkadi05
Drives: Polo 6r Trendline
Post by yassinkadi05 »
ciclo wrote: Wed Mar 04, 2026 5:56 am Hello
Please provide a summary of the procedure you have followed to try to resolve this here without any payment.
It's a strange problem. What's the part number of the BCM Max you're installing?
Its 7H0937090
This happens right after i adopt keys then the engine wont start
ps:I took can high and low from cluster to bcm as in pictures to make work the door mirrors and blinks in cluster to works
If the new BCM MAX is a 7H0 unit, your problem is even stranger.
Please, if you have VCDS, start a new thread in the 6R section and provide an auto-scan (this is absolutely necessary). I will help you there for free, we will surely find the solution to your problem.
What method did you use to pair the keys?
This one? :arrow: https://wiki.ross-tech.com/wiki/index.p ... l_Matching
Please answer my question in your new thread. Thanks.
